Чердачная лестница Oman Nozycowe Lux 500*1200*3000 в Мурманске
| 500 | 700 | 2200 | 3000 | 3250 | - | 500 | 700 | 140 | 1360 | 60 | 56 |
| 500 | 800 | 2200 | 3000 | 3250 | - | 500 | 800 | 140 | - | 60 | 68 |
| 500 | 900 | 2200 | 3000 | 3250 | 3500 | 500 | 900 | 140 | - | 60 | 68 |
| 500 | 1000 | 2200 | 3000 | 3250 | 3500 | 500 | 1000 | 140 | - | 60 | 68 |
| 500 | 1100 | 2200 | 3000 | 3250 | 3500 | 500 | 1100 | 140 | - | 60 | 68 |
| 500 | 1200 | 2200 | 3000 | 3250 | 3500 | 500 | 1200 | 140 | - | 60 | - |
| 500 | 1300 | 2200 | 3000 | 3250 | 3500 | 500 | 1300 | 140 | - | 60 | - |
| 500 | 1400 | 2200 | 3000 | 3250 | 3500 | 500 | 1400 | 140 | - | 60 | - |
| 600 | 700 | 2200 | 3000 | 3250 | - | 600 | 700 | 140 | - | 60 | 68 |
| 600 | 800 | 2200 | 3000 | 3250 | - | 600 | 800 | 140 | - | 60 | 68 |
| 600 | 900 | 2200 | 3000 | 3250 | 3500 | 600 | 900 | 140 | 1300 | 60 | 55 |
| 600 | 1000 | 2200 | 3000 | 3250 | 3500 | 600 | 1000 | 140 | - | 60 | 68 |
| 600 | 1100 | 2200 | 3000 | 3250 | 3500 | 600 | 1100 | 140 | - | 60 | 68 |
| 600 | 1200 | 2200 | 3000 | 3250 | 3500 | 600 | 1200 | 140 | 1850 | 60 | 67 |
| 600 | 1300 | 2200 | 3000 | 3250 | 3500 | 600 | 1300 | 140 | - | 60 | - |
| 600 | 1400 | 2200 | 3000 | 3250 | 3500 | 600 | 1400 | 140 | - | 60 | - |
| 700 | 700 | 2200 | 3000 | 3250 | 3500 | 700 | 700 | 140 | - | 60 | - |
| 700 | 800 | 2200 | 3000 | 3250 | 3500 | 700 | 800 | 140 | 1330 | 60 | 55 |
| 700 | 900 | 2200 | 3000 | 3250 | 3500 | 700 | 900 | 140 | 1300 | 60 | 60 |
| 700 | 1000 | 2200 | 3000 | 3250 | 3500 | 700 | 1000 | 140 | 1850 | 60 | 66 |
| 700 | 1100 | 2200 | 3000 | 3250 | 3500 | 700 | 1100 | 140 | 1270 | 60 | 68 |
| 700 | 1200 | 2200 | 3000 | 3250 | 3500 | 700 | 1200 | 140 | 1850 | 60 | 68 |
| 700 | 1300 | 2200 | 3000 | 3250 | 3500 | 700 | 1300 | 140 | - | 60 | - |
| 700 | 1400 | 2200 | 3000 | 3250 | 3500 | 700 | 1400 | 140 | - | 60 | - |
| 800 | 800 | 2200 | 3000 | 3250 | 3500 | 800 | 800 | 140 | - | 60 | - |
| 800 | 900 | 2200 | 3000 | 3250 | 3500 | 800 | 900 | 140 | - | 60 | - |
| 800 | 1000 | 2200 | 3000 | 3250 | 3500 | 800 | 1000 | 140 | - | 60 | - |
| 800 | 1100 | 2200 | 3000 | 3250 | 3500 | 800 | 1100 | 140 | - | 60 | - |
| 800 | 1200 | 2200 | 3000 | 3250 | 3500 | 800 | 1200 | 140 | - | 60 | - |
| 800 | 1300 | 2200 | 3000 | 3250 | 3500 | 800 | 1300 | 140 | - | 60 | - |
| 800 | 1400 | 2200 | 3000 | 3250 | 3500 | 800 | 1400 | 140 | - | 60 | - |
| 900 | 900 | 2200 | 3000 | 3250 | 3500 | 900 | 900 | 140 | - | 60 | - |
| 900 | 1000 | 2200 | 3000 | 3250 | 3500 | 900 | 1000 | 140 | - | 60 | - |
| 900 | 1100 | 2200 | 3000 | 3250 | 3500 | 900 | 1100 | 140 | - | 60 | - |
| 900 | 1200 | 2200 | 3000 | 3250 | 3500 | 900 | 1200 | 140 | - | 60 | - |
| 900 | 1300 | 2200 | 3000 | 3250 | 3500 | 900 | 1300 | 140 | - | 60 | - |
| 900 | 1400 | 2200 | 3000 | 3250 | 3500 | 900 | 1400 | 140 | - | 60 | - |
| 1000 | 1000 | 2200 | 3000 | 3250 | 3500 | 1000 | 1000 | 140 | - | 60 | - |
| 1000 | 1100 | 2200 | 3000 | 3250 | 3500 | 1000 | 1100 | 140 | - | 60 | - |
| 1000 | 1200 | 2200 | 3000 | 3250 | 3500 | 1000 | 1200 | 140 | - | 60 | - |
| 1000 | 1300 | 2200 | 3000 | 3250 | 3500 | 1000 | 1300 | 140 | - | 60 | - |
| 1000 | 1400 | 2200 | 3000 | 3250 | 3500 | 1000 | 1400 | 140 | - | 60 | - |
| 123 209 | 104 727 |
| 123 209 | 104 727 |
| 123 209 | 104 727 |
| 123 209 | 104 727 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 123 209 | 104 727 |
| 123 209 | 104 727 |
| 123 209 | 104 727 |
| 123 209 | 104 727 |
| 123 209 | 104 727 |
| 123 209 | 104 727 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 123 209 | 104 727 |
| 123 209 | 104 727 |
| 123 209 | 104 727 |
| 123 209 | 104 727 |
| 123 209 | 104 727 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
| 165 656 | 140 807 |
До: 3000 мм;
С 1-ой доп. секцией: 3250 мм;
С 2-мя доп. секциями: 3500 мм
Глубина: 460 мм
Ширина: 300 мм;
Утепление у данной лестницы 60мм (6см) по типу сэндвича, дерево/пенополистирол/дерево.
Лестница крепится к крышке люка (она из дерева) и к самому коробу (он металлический).
Размер 500*1000мм изготавливается под заказ, срок изготовления 35-40 дней. Данную лестницу использовать можно, чаще всего крышки рассыхаются, если внутри помещения холодно или лестница установлена не в помещении, а на улице. Для дополнительной безопасности можно использовать утепляющий короб, устанавливается он на чердаке, так же под заказ.
В Вашем случае, если нет возможности изменить размер проема, то рекомендуем именно эту модель.
Короб можно утеплить самостоятельно, поскольку короб - это ящик, который располагается сверху и многие клиенты его сооружают самостоятельно.
Цену на него предоставляем по запросу.
Получить более подробную консультацию возможно следующим способом:
Металлический короб данной лестницы является теплопроводным. В деревянном коробе лестница будет обладать меньшей тепловодностью и лучше сохранять тепло.
Oman Nozycowe Termo - короб деревянный, толщина дверцы 30мм (не является утепленной лестницей)
Oman Nozycowe Lux - короб металлический, дверь толщина 60мм ( дверь является утепленной)
НО! сама крышка играет роль, больше чем короб. Соответственно Oman Nozycowe Lux сохранит тепло больше.
Если большой перепад температуры, то конденсат будет, но если крышка будет плотно закрыта, то конденсат образовываться не должен, поскольку по периметру короба у данной модели лестницы есть резиновый уплотнитель. Есть лестница со встроенным утепляющим коробом, в этом случае конденсат образовываться не будет, также модель максимально утепленная - Oman Kombo PP 700*1000*3000 (https://www.luchki.ru/catalog/cherdachnye_lestnicy/oman_kombo_pp/oman_kombo_pp_700__1000__3000) Артикул: 171409
Пластиковый замок можно заказать отдельно. Напишите нам на почту mail@luchki желательно с указанием номер Вашего заказа.
