Чердачная лестница Oman Nozycowe 1000*1100*3000 в Мурманске
| 500 | 700 | 2200 | 3000 | 3250 | - | 500 | 700 | 140 | 1360 | 16 | 34 |
| 500 | 800 | 2200 | 3000 | 3250 | - | 500 | 800 | 140 | 1330 | 16 | 35 |
| 500 | 900 | 2200 | 3000 | 3250 | 3500 | 500 | 900 | 140 | 1300 | 16 | 36 |
| 500 | 1000 | 2200 | 3000 | 3250 | 3500 | 500 | 1000 | 140 | - | 16 | 46 |
| 500 | 1100 | 2200 | 3000 | 3250 | 3500 | 500 | 1100 | 140 | - | 16 | 46 |
| 500 | 1200 | 2200 | 3000 | 3250 | 3500 | 500 | 1200 | 140 | - | 16 | - |
| 500 | 1300 | 2200 | 3000 | 3250 | 3500 | 500 | 1300 | 140 | - | 16 | - |
| 500 | 1400 | 2200 | 3000 | 3250 | 3500 | 500 | 1400 | 140 | - | 16 | - |
| 600 | 700 | 2200 | 3000 | 3250 | - | 600 | 700 | 140 | 1360 | 16 | 38 |
| 600 | 800 | 2200 | 3000 | 3250 | - | 600 | 800 | 140 | 1330 | 16 | 40 |
| 600 | 900 | 2200 | 3000 | 3250 | 3500 | 600 | 900 | 140 | 1300 | 16 | 40 |
| 600 | 1000 | 2200 | 3000 | 3250 | 3500 | 600 | 1000 | 140 | 1270 | 16 | 39 |
| 600 | 1100 | 2200 | 3000 | 3250 | 3500 | 600 | 1100 | 140 | - | 16 | 46 |
| 600 | 1200 | 2200 | 3000 | 3250 | 3500 | 600 | 1200 | 140 | 1850 | 16 | 42 |
| 600 | 1300 | 2200 | 3000 | 3250 | 3500 | 600 | 1300 | 140 | - | 16 | - |
| 600 | 1400 | 2200 | 3000 | 3250 | 3500 | 600 | 1400 | 140 | - | 16 | - |
| 700 | 700 | 2200 | 3000 | 3250 | 3500 | 700 | 700 | 140 | 1360 | 16 | 40 |
| 700 | 800 | 2200 | 3000 | 3250 | 3500 | 700 | 800 | 140 | 1330 | 16 | 40 |
| 700 | 900 | 2200 | 3000 | 3250 | 3500 | 700 | 900 | 140 | 1300 | 16 | 40 |
| 700 | 1000 | 2200 | 3000 | 3250 | 3500 | 700 | 1000 | 140 | 1270 | 16 | 40 |
| 700 | 1100 | 2200 | 3000 | 3250 | 3500 | 700 | 1100 | 140 | - | 16 | - |
| 700 | 1200 | 2200 | 3000 | 3250 | 3500 | 700 | 1200 | 140 | 1850 | 16 | 46 |
| 700 | 1300 | 2200 | 3000 | 3250 | 3500 | 700 | 1300 | 140 | - | 16 | - |
| 700 | 1400 | 2200 | 3000 | 3250 | 3500 | 700 | 1400 | 140 | - | 16 | - |
| 800 | 800 | 2200 | 3000 | 3250 | 3500 | 800 | 800 | 140 | - | 16 | - |
| 800 | 900 | 2200 | 3000 | 3250 | 3500 | 800 | 900 | 140 | - | 16 | - |
| 800 | 1000 | 2200 | 3000 | 3250 | 3500 | 800 | 1000 | 140 | - | 16 | - |
| 800 | 1100 | 2200 | 3000 | 3250 | 3500 | 800 | 1100 | 140 | - | 16 | - |
| 800 | 1200 | 2200 | 3000 | 3250 | 3500 | 800 | 1200 | 140 | - | 16 | - |
| 800 | 1300 | 2200 | 3000 | 3250 | 3500 | 800 | 1300 | 140 | - | 16 | - |
| 800 | 1400 | 2200 | 3000 | 3250 | 3500 | 800 | 1400 | 140 | - | 16 | - |
| 900 | 900 | 2200 | 3000 | 3250 | 3500 | 900 | 900 | 140 | - | 16 | - |
| 900 | 1000 | 2200 | 3000 | 3250 | 3500 | 900 | 1000 | 140 | - | 16 | - |
| 900 | 1100 | 2200 | 3000 | 3250 | 3500 | 900 | 1100 | 140 | - | 16 | - |
| 900 | 1200 | 2200 | 3000 | 3250 | 3500 | 900 | 1200 | 140 | - | 16 | - |
| 900 | 1300 | 2200 | 3000 | 3250 | 3500 | 900 | 1300 | 140 | - | 16 | - |
| 900 | 1400 | 2200 | 3000 | 3250 | 3500 | 900 | 1400 | 140 | - | 16 | - |
| 1000 | 1000 | 2200 | 3000 | 3250 | 3500 | 1000 | 1000 | 140 | - | 16 | - |
| 1000 | 1100 | 2200 | 3000 | 3250 | 3500 | 1000 | 1100 | 140 | - | 16 | - |
| 1000 | 1200 | 2200 | 3000 | 3250 | 3500 | 1000 | 1200 | 140 | - | 16 | - |
| 1000 | 1300 | 2200 | 3000 | 3250 | 3500 | 1000 | 1300 | 140 | - | 16 | - |
| 1000 | 1400 | 2200 | 3000 | 3250 | 3500 | 1000 | 1400 | 140 | - | 16 | - |
| 94 738 | 80 527 |
| 94 738 | 80 527 |
| 94 738 | 80 527 |
| 94 738 | 80 527 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 94 738 | 80 527 |
| 94 738 | 80 527 |
| 94 738 | 80 527 |
| 94 738 | 80 527 |
| 114 719 | 97 511 |
| 94 738 | 80 527 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 94 738 | 80 527 |
| 94 738 | 80 527 |
| 94 738 | 80 527 |
| 94 738 | 80 527 |
| 114 719 | 97 511 |
| 94 738 | 80 527 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
| 114 719 | 97 511 |
До: 3000 мм;
С 1-ой доп. секцией: 3250 мм;
С 2-мя доп. секциями: 3500 мм
Длина: 1100 мм
Длина: 1100 мм;
Глубина: 430 мм
Ширина: 400 мм;
